Sponsored by: Real Truck
anything we can do about a/c?
Old Sep 24, 2007 | 10:13 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by Netfly
big honking is that a Home Depot plumbing or auto store type?
Marine store - well, wholesale, anyway...
I use to run a cable controlled one on an old charger, but it wasn't one made for the car. I think it fit something from the early 60's. I supplied a manual choke cable control from inside the cab and the mechanical valve worked well. I wish I knew what car it was from.
My brother did the same thing to my highboy when he got it brand-new in 1974 - I used it all the time
Old Sep 24, 2007 | 11:29 PM
Netfly's Avatar
Netfly
Thanks krewat. I found one for a 66 chevy c20 that is close, but the control doesn't look like it will take a single cable easily.
http://www.partsamerica.com/productdetail.aspx?MfrCode=FAA&MfrPartNumber=74661 &PartType=394&PTSet=A
I'll keep looking.
Old Sep 25, 2007 | 12:54 AM
Netfly's Avatar
Netfly
OK. The valve makes sense when you see it with a bracket.
http://www.bouchillonperformance.com/BPEheaterValve.asp
Old Sep 25, 2007 | 07:22 AM
bookum1's Avatar
bookum1
I have a silly question, but does this work equally as well on GAS engines. I have a 01 f250 v10 and AC checks out fine, but not cold enough
Old Sep 25, 2007 | 02:56 PM
krewat's Avatar
krewat
Mine IS a gas engine - helped lots to cut off the heater core.
Old Sep 25, 2007 | 04:08 PM
Kevinpmac's Avatar
Kevinpmac
Originally Posted by skyphix
Overcharging the AC system in cars can also cause warm air. It should be a specified poundage. I hope thats what you mean by "maxed out".
It's filled properly. Actually tried putting in a little extra and it made no difference. Immediately went back to proper fill to be safe.
edit: I just pulled the trigger on the Dieselsite kit (see link, page 1). For $42 you get the complete kit with detailed instructions. No brainer in my book...
Old Sep 25, 2007 | 05:03 PM
jim henderson's Avatar
jim henderson
That sounds like an idea. My 94 460 gasser puts so much heat thru the vents that it isn't worth using the vent position of the system unless it is cold outside. AC is cold but could be colder on really hot days.
Jim enderson
Old Sep 25, 2007 | 05:30 PM
Netfly's Avatar
Netfly
Where can you access the max air vacuum signal under the hood?
Old Sep 25, 2007 | 06:40 PM
Netfly's Avatar
Netfly
I read the other threads and max air is the white vac line under the pass glovebox behind a panel.
Old Sep 29, 2007 | 05:19 PM
Kevinpmac's Avatar
Kevinpmac
Installed the kit this morning and WOW, what a difference. I actually have A/C that blows cold in 90 degree Florida heat. Thanks for the info guys.
FYI- the white vacumn line was hard to find on my 01 Lariat. I swung the glove box door down to the extended position (squeeze sides) to see the vacumn line. I could then easily trace where it plugged into the little silver canister.
Old Oct 5, 2007 | 05:48 PM
DavidE200016936's Avatar
DavidE200016936
I had two mechanics tell me a/c was charged, then the idle was bouncing all over the palce and the compressor was cycling alot. Went to Advance and bought a can of the refill, it suck it in in 30 seconds! The cycling slowed down and the idle got better. Put two more cans in and it now is like an icechest, the idle is normal and the poor compressor sounds much happier..The disposable recharge cans come with a gauge and work ok.
Old Oct 5, 2007 | 09:03 PM
Heavy Haulin's Avatar
Heavy Haulin
One other thing you guys can try if your truck is more than a few years old is cleaning your evaporator off. I read about this on another site and decided to try it. I had already done the heater core valve and was still not happy with my 99's a/c. If you remove the blower fan under the hood you can look down inside the a/c housing and see about 1/3 of your evaporator. If its like mine was it is covered in dust/dirt/hair etc. I took my water hose and cleaned it out for about ten min making sure only to flush alittle at a time so the water could drain off. its a really easy job and man o man did it make a diffrence. I used to barely be able to stay cool on max a/c fan #4 , now i usually run it on fan #1 and am freezing. This helped big time not only on the coolness of the air but also on my fan output too.
Old Oct 6, 2007 | 09:47 AM
  #28
JIM ROLAND's Avatar
JIM ROLAND
<TABLE><TBODY><TR><TD vAlign=top width="100%">If anyone reading this thread would like to do the cheap, easy, manual cut off valve method, the NAPA part # for the valve is 660-1414, clamps part # is 505-1212. I spent a total of $14.77 + tax for the valve and two 5/8" stainless steel worm gear clamps. I installed it on my 2000 F250 4x4 7.3 powerstroke next to the oil filler cap. It worked great today with outside temp. at 105 and heat index of 115. For anyone who may not know which heater hose to install it in, it is the one that carries hot water into the heater core, it will be the one coming from the engine and going toward the firewall, not the one which connects to the water pump. I mounted mine at this location for very easy access by just reaching in over the passenger side fender. It took a total of five minutes to do. When installing make sure your clamps etc. are not touching any other metal so you won't have any rattles or abrasion.This is for the guys like myself who just want an inexpensive easy fix. Thanks to all on this thread!
</TD></TR></TBODY></TABLE>
Old Oct 6, 2007 | 11:31 AM
  #29
rbaker6336's Avatar
rbaker6336
this is something I use to have to do at least twice a year on my dump trucks
Old Oct 6, 2007 | 07:45 PM
  #30
JIM ROLAND's Avatar
JIM ROLAND
Just so you guys won't think I'm crazy, the above post (#28) was done back in the summer. No, it was not 105 degrees here in Florence today! LOL I done a copy and paste. Please excuse.
