im second owner was used as work truck before i got it so all paperwork is gone along with my haynes manual aint gotta clue were it went. thanks though
Take off the top cooler line on the radiator .... stuff a rubber plug into the rad hole ( sometimes it tries to puke out some there ). Hook a hose to that cooler line you got hanging and place in a 5 gallon bucket to catch oil comming out . Get about 12 quarts ready to pour . Crank her up , and while the old fluids squirting into the bucket , you need to be pouring new stuff into the dipstick .... and watch for the color to turn pink going into the bucket .... when its pink , shut her off .
Replace the cooler line , crank her up and check level . Add if needed .
(Oh and try to be pouring fluid back into the dipstick , the same rate as is comming out into the bucket .... Yea its a rough guess .... but you dont want the pan to run dry for long . You can tell if you are too slow adding it .... because the fluid will be sputtering out the rubber tube in the bucket )
for the mazda 5 speed it is 7.6 pints which is 3.8 quarts and for the zf 5 speed it is 6.8 pints which is 3.4 quarts. are you going to put the atf back in it? when I put new seals and the 3 plugs in mine I used royal purple synchromax oil.it is an all synthetic oil designed for transmissions using the atf. I did that in 2005 and it still shifts smooth.
when i get the time and energy i am going to change the rear end 80-90 oil to royal purple max gear synthetic 75-140.
i am just starting to do things on my truck again,after my operation,chemo and radiation for pancreatic cancer starting in april of 2006. Jack
