c-6 tranny interchange
Old Sep 23, 2007 | 10:41 PM
9d4's Avatar
9d4
I hve been looking for a c-6 for my 74 f-100 4x4 as mine is toast. I found one out of a 79 f-150 390 but it's a 2 wheel drive. He said all you have to do is pull the tail shaft and bolt it to the transfer case. I was under the impression that you could not use a 2wd in a 4x4 unless you had the divorced transfer case wich I do not. Does this sound right??
Old Sep 23, 2007 | 10:48 PM
masterbeavis's Avatar
masterbeavis
You have to completly disassemble the transmission to change out the tail shaft. You can take your 4x4 transmission apart and put in the 2wd parts. It seems difficult, but if you pay close attention to how everything comes out, and lay it out as it comes out, and keep everything super clean, you can pull it off. An ATSG maunual wont hurt either. you can get them at ebay, or search the net.
Old Sep 23, 2007 | 11:08 PM
9d4's Avatar
9d4
great thanks for the info
Old Sep 24, 2007 | 11:16 AM
Mil1ion's Avatar
Mil1ion
The NSS is different as well.
On the 79 it is on the transmission.
On the 76 it is on the column
Old Sep 24, 2007 | 08:35 PM
masterbeavis
Awe c'mon, who needs a neutral safety switch?
