when i raise the rear end and spin my wheels
Originally Posted by Matts72
Except that Dana called it a Power Lock, so close but no cookie this time ... Most of the LS units put in ford trucks for the rear axle were Dana 44s in half tons and Dana 60s for F250/F350s
I had only driven it a very short distance before jacking it up,because it needed brake work,i don't recall any odd noise,it just caught my attention that both wheels spun together,cause i've never seen that before. I was actually exited,thinking i had a really good locker that i didn't know came with the deal,i didn't get worried until i read the reply that it meant a broken carrier.and no,nothing to harsh in the gear oil,just what you'd expect from probably not getting changed in who knows how long.
#28
#29
Are you guys not seeing the pictures that he posted? I'm certain that he posted pictures of an open differential. DO NOT add Limited Slip additive to any differential that does not have a clutch type limited slip.
Tony-
Ford called their setup a trac lock, only used in Ford manufactured axles, Dana called their setup a power lock, only used in Dana manufactured axles. The two systems are different, dana only offered the power lock, in the second set of pictures, or the open differential in the first set of pictures.
Tony-
#30
The third picture (fuzzily) shows the clutches. (left side of the spider gears)
Take a look at these links, tell me what you think.
Bookmark this link here, lots of good stuff.
http://www2.dana.com/expertforms/depdf.aspx?prod=AXL
Dana Spicer Trak Lok manual
http://www2.dana.com/pdf/5314-2.PDF
Dana Spicer Powr Lok manual
http://www2.dana.com/pdf/5315-3.PDF
If I am still wrong, or maybe there is something I am not understanding, lets move this discussion to another thread, instead of continuing the hijack here.
