Power windows and locks
Old Sep 23, 2007 | 08:56 PM
blinkjs's Avatar
blinkjs
I started what I thought to be a couple weekend project. Repainting my 94 F150. Well over a month later I'm starting to run out of steam. Everything fought me the whole way. Here is the newest thing. I re-hung the doors and re-installed all the electrial connections for the power doors and locks. Turned the truck on and nothing works. Please tell me I've overlooked a small detail? and yes I've checked all the connections in the doors multiple times. The rear speaker also decided not to work anymore. I'm getting power to the lights and front speakers, but nothing with the windows or locks. Any suggestions?
Old Sep 24, 2007 | 07:31 AM
Musclestang's Avatar
Musclestang
you see that black rubber when you open the door in the hinges area ? Wiring harness goes thru there ..... pull it back if you can , or slit that open and see if there are wires broken in half .
After years of opening the door .... and those wires having to bend back n fourth .... they break . If its not there , then post back .
Old Sep 24, 2007 | 08:17 AM
Conanski's Avatar
Conanski
FYI... all the switches on both doors have to be plugged in before the devices will operate. Been there, done that.
Old Sep 24, 2007 | 09:52 AM
blinkjs's Avatar
blinkjs
thanks I'll check those suggestions out this evening
Old Sep 24, 2007 | 07:40 PM
Old_Paint's Avatar
Old_Paint
Please, say you didn't put the door panel back on with the wire harness disconnected. Not that I would do such a thing, but I've seen it happen. :P
Old Sep 25, 2007 | 08:06 AM
blinkjs's Avatar
blinkjs
Got it figured out last night. There was a connection that wasn't totally tight(under the dash near the clutch pedal. thanks for all the suggestions
