Holly red Pump install
Old Sep 23, 2007 | 05:43 PM
carmenhunter's Avatar
carmenhunter
Question Holly red Pump install
Have 84 F350 6.9w/Banks C6 4x4 thinking of installing a holly red FP To get rid of Mechanical pump. Any thing I should know about (problems) I have installed electric pumps on trucks and equipment before never on this perticular vehical. Just dont like suprises THANKS
Old Sep 23, 2007 | 06:57 PM
mechmagcn's Avatar
mechmagcn
Although I am sure the Holley pump is a quality part, I have had better luck with the Carter vane type pumps. I can't recall the part # but you need one in the 7-8 PSI range.
Old Sep 23, 2007 | 07:24 PM
72f2504x4390's Avatar
72f2504x4390
The holley red pump is a vane pump also. Quality on the holleys is good, better than the carter in my opinion, plus you can get rebuild kits for them for about $20. The holley red is 7psi.
No big surprises. You might want to check the pressure at the filter after you put it on. I just put on a Mallory gerator type pump that is supposed to be a 7psi pump and its putting out 11psi. I am having issues that may be related to that but I am not sure yet.
Make sure you don't run it through the stock pump, not a good idea.
Old Sep 23, 2007 | 07:26 PM
72f2504x4390
Forgot this.
I mounted mine right next to the fuel tank selector to the bottom of the cab with two rubber bumpers under the mount and you can't hear the thing with the truck running.
Old Sep 23, 2007 | 07:44 PM
RunRed's Avatar
RunRed
I just got me an electric FP, I put it on the that big plate on the fender well (the plate that holds the voltage regulator and some other things, got me a bunch of clear hose so I can see if it bubbles, and just cut the steel line running from the racor to the main fuel filter..in half and ran the FP lines into it.. I haven't driven it yet since I got coolant problems but I am hoping I can get some smoke. I turned the screw one flat a couple weeks ago and didn't notice ANY difference.. figure this extra FP should kick it in the rear..
Old Sep 23, 2007 | 08:16 PM
redneckaggie2008's Avatar
redneckaggie2008
I have installed one before and it didn't seem bad at all. I used rubber hose from the stock lines to the fuel pump on each side and it sealed easy. The only problems I ran into is you have to find some type of stiff rod to go inside of the stock lines. I used some brake line off of an old truck we had here. This keeps the line from collapsing and pinching off.
Old Sep 23, 2007 | 08:40 PM
redneckaggie2008
Oh yeah and put it as close to the tank selector as possible. Any check valves should be after the pump. A fuel pump is a pusher not a puller
Old Sep 23, 2007 | 10:11 PM
fellro86's Avatar
fellro86
The pump really needs to be at minimum the same level as the tank, better to be close to the tank, they don't pull uphill very well at all.
Old Sep 24, 2007 | 07:19 AM
RunRed's Avatar
RunRed
Well if the mechanical pump is feeding it I really wouldn't think it would have any probs.. but maybe I am wrong?
Old Sep 24, 2007 | 07:37 AM
72f2504x4390
But why would you want 2 pumps inline? Can't seem to see the benefit.
Old Sep 24, 2007 | 07:41 AM
fellro86's Avatar
fellro86
so you have the electric after the mechanical? Haven't heard that one being done, mainly because the mechanical is doing all the work, and the electric is just sucking electricity to do no additional benefit. If it was at the back, it can help the mechanical, although not recommended due to possibility of the mechanical failing and then the electric would put fuel into the crankcase.
Old Sep 24, 2007 | 11:11 PM
RunRed's Avatar
RunRed
Helps it start, makes changing fuel filters and bleeding it as easy as it gets.. I figure it can't "hurt" anything..
Old Sep 24, 2007 | 11:37 PM
72f2504x4390
But it would be the same if the mechanical was out of the picture.
Old Sep 26, 2007 | 10:44 PM
ford trans tech's Avatar
ford trans tech
with it mounted that high it wont pump without the mechanical pump supplying it
Old Sep 27, 2007 | 11:11 AM
shorthair's Avatar
shorthair
I used a purolator pump on the frame rail next to the selector switch so much cheaper than the holley red that I bought a spare to throw in the tool box. Supplies plenty of fuel to get 16,000# up a 6% grade from a stop at the bottem.
