Sponsored by: Auxito
Engine Missfireing/Shimmers
Old Sep 23, 2007 | 02:05 PM
darrock57's Avatar
darrock57
Question Engine Missfireing/Shimmers
Hello, I'm new today. I have read several Q&A and have already fixed a problem, Thanks
Here is my first question... I have a 1999 F150 4x2 Supercab. It has the 4.6 V8 with approx 110,000 miles. About a month ago, I noticed when I started it one morning, if started missing. I first thought it felt like my trans was slipping but that is not the prob. It's gotten worse. It shimmies at idel and then upon accell and at around 35-40 mph.
I have done all the upper area cleanup to the throatle body,MAS,Valve that sences the accell preasure next to throatle body, new plugs and new fuel filter. I do not get a Check Engine light. I stopped by a Autozone and they connected a code scanner and there are no codes.
Sorry for lack of part names knowlage.
any ideas ?
Darrock57
Old Sep 23, 2007 | 09:32 PM
torkum's Avatar
torkum
You didn't say anything about plug wires. Also take your 2 coil packs down to Auto Zone and have checked. I think the part you were trying to describe is the TPS [throttle position sensor].
Old Sep 29, 2007 | 12:28 AM
2002f150owner's Avatar
2002f150owner
Does it miss when you're at speed or only when you're idling?
