1999 ranger 2wd four cylinder auto with 4.10 rear. Stock tranny cooler built into radiator. I have a little 5x8 tilt trailer i am thinking of pulling with it, and haul my little commercial walk-behind mower. I figure trailer and mower couldnt be more than a 1000 pounds. Would this truck do okay pulling this? The only thing that bothers me is the auto tranny. So what do you all think? Should i try it? I could save some gas versus hauling it my ole f-150..
Absolutely! Although I wouldn't recommend it on a daily tow I've towed a 16' tandem axle loaded with 2 tons of posts and fence up to my cabin on the hill several times and she did just fine and didn't sag. I also have a 5x8 tilt trailer that I use for various smaller chores such as hauling mowers, 4-wheeler, etc. with no problem.
JUST KIDDIN, I have always been told that with an auto tranny not to pull a traileer in overdrive. I am not sure if it is right or not. I have a f250 v10 with an auto as welll I will be checking in the no overdrive thing aswel because i plan on tring to start my own lawncare/ landscaping buss. inn the spring.
for the size trailer and weight I think that is gonna be the perfect truck for you. I keep watching these local landscapers with there 1 ton diesels pulling that size trailer will some extra hand tools and a weedwacker. to me thats a waste of money, and not good for the motor, as most lawncare guys do local trips, drive 15 mins, do a lawn, drive 15 more, do a lawn, drive 15 more, etc. You catch my drift. So for your situation i think it's perfect truck for the task.
take it out of overdrive and you could haul almost anything it wont hurt it trust me ive abused my truck for 151K over 8 years and the trans is finally starting to go.. the exact same setup you have
