Voltage Regulator....Prob I think???
Old Sep 25, 2007 | 09:48 PM
fasthauler's Avatar
fasthauler
I am a little confused as to what you have but if it is a standard ford setup then the grounding is extremely important as I said earlier. There is caution statements on a lot of the VR's. If you plug them in before bolting them down they will destruct because they get a ground through the case. If that VR bolts to the fenderwell and the fenderwell has a poor ground it can destruct the VR as well.
CATFORD's Avatar
CATFORD
Just re wired and terminated everything from the Alternator, Voltage Regulator and Battery.....
Started the truck and first got about 14.5 V.....but after runnng for 2-3 minutes it climbed to 16.5 volts....
Not sure what to do next other than go swap the voltage reg I brought for another new one and try that....
What should be the next item to do.....I thinking alternator but I really dont know!!!
Cheers Rory
Old Sep 25, 2007 | 11:10 PM
Mil1ion's Avatar
Mil1ion
Has a battery cable ever been removed with the engine running ?
That will blow diodes in alternator.
Old Sep 26, 2007 | 02:05 AM
CATFORD's Avatar
CATFORD
Not while I have had it....but who knows previous!!!!
Old Sep 27, 2007 | 10:06 PM
CATFORD's Avatar
CATFORD
Well....it's time to have a good laugh at a stupid AUZZIE!!!
Truck is fixed....after re-terminating and changing the regulator...I was confused....I triple checked everything and still was getting 16-18 Volts....So I decided I will part with $170 (AUD) to rebuild the alternator! Before removing I thought I would check my other two cars to compare voltage ( 1980 Honda Civic and 2002 AU FALCON UTE ).....on placing the multimeter on the battery of the civic while running it read 17-19 volts.....I then check my Ute running and suprise, suprise it also read 17-19 Volts.
So all along my multimeter was stuffed.....lucky I didnt go blow another $170 on something not broken!!!
Dame stupid AUZZIES!!!
Anyway thanks for all your help during my believed problem...thankfully there was nothing wrong with it!!!
Thanks Again Rory!!
lign
Oct 19, 2013 01:37 PM
72camperspecial
May 28, 2013 09:12 PM
goofynick6
Large Truck
Sep 15, 2012 09:17 AM
Barndon
16
Jan 12, 2010 09:14 PM
leardvr
Jun 7, 2009 02:04 AM
