Exhaust back pressure sensor.
Old Sep 21, 2007 | 08:35 PM
99powerstrokeSD's Avatar
99powerstrokeSD
I have replaced my exhuast back pressure sensor and the truck is still throwing a low voltage code. I know that they make something to plug into that plug the bypass the system and send the CPU the correct voltage and there by not throwing a code and keeping the check engine light off. Does anyone know who sells this? Also does anyone know how to get the light off without this gizmo?
Old Sep 21, 2007 | 08:48 PM
medhvac's Avatar
medhvac
why don't you just disable the EBPV so you will never have this problem again. Dfuser. com sells plugs for this. One plug is for the sensor (above water pump) and the other plug is for the valve(on the front of turbo). You will never throw a code again and your valve should never operate. From reading on here, lots of people that live in cold climates have disabled their EBPV with no problems.
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Is this what you are looking for?
http://www.puredieselpower.com/catal...age-p-108.html
Old Sep 21, 2007 | 09:11 PM
99powerstrokeSD
puredieselpower.com has a stage 1 and a stage 2 which is the best?
Old Sep 22, 2007 | 01:30 PM
Texas Outlaw
Not a liberal...
I have no idea as I do not run one. I think Ron (Ron's Power Stoke) runs one of those. You might ask him.
