Calling all high idle modders!
Old Sep 21, 2007 | 07:45 PM
UGA33's Avatar
UGA33
Just curious but what are yall w/ gauges reading, egt wise, while you have high idle engaged?
Old Sep 21, 2007 | 10:39 PM
mhoefer's Avatar
mhoefer
High idle reads about 550 to 600 degrees pre turbo on mine but thats at outside temp of 55 to 65 degrees F ambient air temp. Goes a bit higher if hotter outside but not much. This winter will find out if it keeps it over 400 when idling at -40.
Old Sep 22, 2007 | 04:49 PM
JReinert's Avatar
JReinert
My truck reads about 325-375 depending on outside temps. Doesn't seem to raise it that much, but anything helps.
Old Sep 22, 2007 | 05:04 PM
MrMike06's Avatar
MrMike06
Yeah my guage reads maybe 50-100 degrees hotter then when im at an idle.
Old Sep 22, 2007 | 11:43 PM
UGA33's Avatar
UGA33
Thanks for the replies. I set at 400 degrees at normal idle w/ the a/c off. High idle bumps it up 70-100 degrees. Just trying to get an average
