Sponsored by: Real Truck
charging light stays on
Old Sep 21, 2007 | 05:47 PM
mr_glass's Avatar
mr_glass
I have a 02 f250 dsl that I just changed the engine wiring on. Oil soaked and crumbling wiring on the injector wires. Everything went fine but when I finnished the charging light stay on. With ignition on and unhooking the alt connector the light goes out. Tried a reman alt and a aftermarket new alt, light stays on. Only getting 2 volts on the grn/red wire off the alt. The truck is charging with all three alts that I tried. Any ideas? Thanks Chris
Old Sep 25, 2007 | 09:22 AM
mr_glass's Avatar
mr_glass
Fixed it. FYI using a new harness from ford the red/blue wire on the alternator was routed to the main harness instead of directly to the battery. Ran a fuseable link and jumper wire from the battery to the red/blue wire and the light went out and the truck was charging. Thanks Chris
