Stacking?
Old Sep 20, 2007 | 03:02 PM
suzuki_vinson's Avatar
suzuki_vinson
Question Stacking?
My friend has a superchips tuner for his truck. He recently bought a ford evolution. He is running the evo by its self now. Can you stack these???
Old Sep 20, 2007 | 03:17 PM
John311t's Avatar
John311t
No, there is no reason to anyways. If the evolution lets you put there tunes while having the superchips on there, ill be surpised, you will see no difference. The superchips programming would get overwritten with the evolution programming.
Old Sep 20, 2007 | 04:55 PM
ron's power stroke's Avatar
ron's power stroke
be a friend and tell him to sell them both and get some custom tuning like a dp tuner ...up to 16 switch on fly, good safe HP.. IMHO !! a lot better then any 2 of the off the shelf chips put together..
Old Sep 20, 2007 | 08:59 PM
nmcqueen469's Avatar
nmcqueen469
It will not work, tried it personally. The evolution is much better that the superchips if a choice between the two must be made.
Old Sep 20, 2007 | 09:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
The way the tuners load the programs both use the same method. The tuner saves the stock PCM program to the tuner and loads the tune to the computer. You can only load ONE tune the the PCM without piggybacking a chip onto it. Im sure if you were to try to stack them it would throw it back at you and not let it happen. However you can stack a tuner with a fueling box (Juice/attitude,Six gun) because they both use different methods. However like it was previously mentioned, a chip is the best way to go.
