Sponsored by: Auxito
Light Switch Changeover
Old Sep 20, 2007 | 12:18 PM
sumoboy's Avatar
sumoboy
Hi, guys. I just got this truck after getting rid of the 05 F150. It's a 2003 F150 , with the 4.2 V6. My question is about the headlight switch and the inside rear view mirror. The truck has regular switch and mirror now. Does anyone know if the truck can be retrofitted with the automatic light switch and the corresponding mirror with light sensor in it?
Old Sep 20, 2007 | 03:24 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
You would have to take the entire dash out and put in a harness from a truck that had that... the harness runs from one side to the other and plugs into everything... including the doors... its do able... but its best to have a donor truck and your going to want to have to do it cause it will be time consuming...
Im thinking you will need to check into the PATS system to...it might **** it off by switching some of that.. it might have to be reprogramed after you do that... but im not sure...
Old Sep 21, 2007 | 07:23 AM
sumoboy's Avatar
sumoboy
Thanks. As a Mercedes parts guy for the last 17 years, I was hoping it wouldn't be as bad as a highline vehicle. I'll just keep turning my lights on and off by myself.
