code 32 help?
Old Sep 20, 2007 | 11:22 AM
cleeE150's Avatar
cleeE150
code 32 help?
truck first start, stalls 2nd start, idles up and down, till warms up, then mild surging, at idle or cruising 0-10 miles per hour, otherwise running good, pulled code 32, whats best way to fix? any help thanks..
Old Sep 20, 2007 | 07:42 PM
Frat-man-du's Avatar
Frat-man-du
Key on Engine off code 32:
EVP circuit below minimum voltage of 0.24 volts.
Cont. Memory code 32:
EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
Old Sep 20, 2007 | 07:45 PM
Frat-man-du
The EVP is the sensor on top of the EGR Valve.
Old Sep 21, 2007 | 05:45 AM
cleeE150's Avatar
cleeE150
Red face
thanks would this then be sensor and or sensor wiring, poss bad, or can it also be egr valve not working?
Old Sep 21, 2007 | 05:59 AM
cleeE150's Avatar
cleeE150
Frat-man-du, seen your post, and pics on post, now I know what to ck. I remember now, I had this same problem about 8 years ago,replaced sensor, redid vacume lines ect, also remember had tromble with new sensor , pintal shaf I beleive it was called, was to short needed different o-ring I think? thanks foe reply.....
