Read through several pages in the forum and didn't run into this one so I ask. '02 F-250 SD 7.3 A.C. cuts off at speeds >62 M.P.H. Anything below works like a champ even idling in traffic. Get on the highway above 62 and after a few seconds air begins to warm. You don't get cold air again until your speed decreases below 62. While I'm sure 62 is not a magic number for this type of problem it is mine, anyone else? Whats the fix?
On your truck, the compressor clutch is controlled directly by the computer (via a relay). Therefore, I can only suggest that the computer is either acting on an incorrect sensor input or mis-handling the data that it is receiving.
A scan tool looking at live data would be recommended to look at several of the A/C related PIDs to get a better picture of what's going on.
I don't know what the problem is, but 62mph corresponds to 100km/h. It's acutally 62.5mph but it seems that whatever it's doing is triggering off of 100km/h (bad sensor input, bad data, etc...)
It could be at the high speed it is lowering the pressure and throwing the low pressure switch, will it cut out in neutral if you bring the motor up to the cruising rpms?
If so you need a recharge!!
Let him try to bring it up to the same rpms and see if it will recreate it, before telling him to go spend money at a shop!! If the truck hasn't been recharged since it is new it is probably due!! Yes when the vacum gets increased from the higher rpms it will lower the pressure enough to cause it to cut the low pressure switch if it is just a bit low on freon!!
