Tonight I was testing my glow plugs to see which ones were bad. On the right side bank on the back plug, the outside prong closest to the firewall is melted. I unplugged it and noticed a piece of the plug missing. I looked where it plugs into the valve cover gasket, and it is still in there. It either broke off or melted. Can you buy just that end of the plug so I can cut the wires and wire up the new one. Or any suggestions? Its a 97 F350 PSD Thanks
P.S. I need the plug end on the wiring harness not the valve cover gasket end. I think i can get the broken piece out with needle nose pliers. But the harness end is shot it needs to be replaced.
If the valve cover gasket side is melted I would go ahead and replace it. I think it's only 30-40$ if I remember right. I would replace it all in my opinion.
You can replace the connectors. Here are some part numbers to help you. Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Pigtails with plug and wires, OBS
(Performance Specialties) 99288
(Ford) F4TZ-12A342-A
Its Very Easy To Do. Look At My Pics To See What All You Need. Comes With A Tool. Splice A New Pin Onto The Burnt Wire And Put All The Pins Into The New Plug. Make Sure You Do Up A Diagram Before You Rip It Apart.
