2001 Expy Idling Problem
Old Sep 19, 2007 | 05:30 PM
RayRay301's Avatar
RayRay301
Hey guys. My wifes 2001 Eddie Bauer 5.4 has an idle issue. When starting it in the mornings, it won't idle. If you keep your foot on the accelerator it will idle. After about 10 minutes it smooths out. It don't do it all the time, but it's happening more often now. (3 out of 5 times). Any suggestions? BTW, I replaced the TPS last night, it didn't help. My 2000 Mustang GT had a similar problem and it was the TPS. Could it be IAC or MAF sensor? Vacuum leak? Also, it's not throwing any codes. Thanks in advance, Ray
Old Sep 19, 2007 | 08:59 PM
Gevans17's Avatar
Gevans17
Happens to all of us Ford owners
IACV - Idle air control valve - gummed up.
2 bolts on top of throttle body
easy to change
Old Sep 20, 2007 | 03:22 AM
RayRay301's Avatar
RayRay301
Thanks. That is what I suspected after reading some other posts. I'm going to change it this afternoon. Ray
Old Sep 20, 2007 | 08:09 PM
Frat-man-du's Avatar
Frat-man-du
Yeah, IAC most likely- cam or crank sensor after that.
