Ticking while braking?
Old Sep 19, 2007 | 01:22 PM
gdhagleriii's Avatar
gdhagleriii
I have noticed for the past few months when i do a sudden stop i here a ticking noise coming from under the hood. when im doing normal braking no noise. What would the ticking be from?
Old Sep 19, 2007 | 04:50 PM
wendell borror's Avatar
wendell borror
It's the abs I would say.
Old Sep 19, 2007 | 06:27 PM
blue beast's Avatar
blue beast
Could be the calipers need some lube on the mounting surfaces! They probably are just heat expansion creaking ticking whatever noise it makes! The rust is probably in there between the caliper mount and caliper moving around, Try spraying out the caliper area with a power washer and see if it cures it for a couple of days, If it does get some high temp grease and take off your tires and lube up the sliding parts!!!!
Old Sep 21, 2007 | 04:59 PM
wendell borror
My truck makes that noise when I apply the brakes hard, it's the abs, there's a valve on the master cylinder that controls the abs. But you may have another issue, the abs poped in my mind first thing when you described how it was acting.
Old Sep 21, 2007 | 09:06 PM
blue beast's Avatar
blue beast
I just realized it said under the hood!! Opps maybe he'll post back with more info!!
