In bed camper
Old Sep 19, 2007 | 08:03 AM
wcurtis's Avatar
wcurtis
In bed camper
I'm borrowing a "in bed" camper to take a fishing trip to New York to do some Salmon fishing. I will be driving about 500 miles & pulling a 16' bass boat behind my F250 5.4 auto with 373 gears. I was told that the camper weights about 1300lbs empty. My question is I have never driven with a camper in the bed what should I expect?? I have done a lot of towing so I not worried a lot. but is there anything I should worry about???
Old Sep 19, 2007 | 09:06 AM
Mich F's Avatar
Mich F
Since you do not normally carry a slide-in camper, does your truck have a tie down set up for the camper? Assuming that you do, you shouldn't have any problems. My truck, a 2004, is the same as yours. I carry a 2,600# +/- slide in and tow a 6,000# boat and trailer without any problems.
Old Sep 19, 2007 | 10:58 AM
97squarebody's Avatar
97squarebody
Hello all;
Other than felling a little top heavy at first, you should be fine. You will get used to the feeling fairly quickly. Just think about this before you enter a sharp corner.
Easy, easy, easy...
Old Sep 19, 2007 | 05:16 PM
wcurtis's Avatar
wcurtis
Thanks for the replys, I'm going a have a ball fishing, check out the pictures my gallery Of my trip from last year
Old Sep 19, 2007 | 09:21 PM
Spamjohnson's Avatar
Spamjohnson
Is it a pop up or standard camper, I will echo the tie down warning. Good tie downs mean piece of mind. Make sure you don't have a bedliner, the camper slides REAL easy with that in. Depending on the style you might need to Y the trailer plug to light the camper and trailer. I have a 2000 pound camper and my truck felt kinda rocky around corners until I added air shocks.
Old Sep 19, 2007 | 10:11 PM
wcurtis's Avatar
wcurtis
I have tie down that are bolted to the bed side with turn buckles on them, & it is sitting on a rubber mat.
Old Sep 19, 2007 | 10:28 PM
Spamjohnson
Good deal, I like the frame mounted ones better, but that should do you, what kind of wiring on the camper 4 pin or trailer type plug?
Old Sep 19, 2007 | 10:43 PM
wcurtis's Avatar
wcurtis
It has the plug type, but the boat has a 4 pin, And I have both set ups on my superduty. so I will be able to plug both in
Old Sep 25, 2007 | 07:24 PM
smokestone52's Avatar
smokestone52
Oh wow, does this bring back the memories. I had a 1979 F-250, with a 8' Lance. I towed, an older Ski Nautique. Man what a way to raise kids. Getting them outta town, camping, boating. And yes I fished out of my Nautique.
You will do well my friend. Enjoy!
