1978 - 1996 Big Bronco
Broken Brakes?
Old Sep 18, 2007 | 11:08 PM
Red91XLT's Avatar
Red91XLT
Broken Brakes?
Okay, so over the last... maybe three days? My brakes have gotten alot stiffer & I've noticed a very loud hissing sound. Now I'm not master mechanic or anything like that, but this truck has had several vaccum leaks and I've done my best to repair them. So what I'm guessing has happened is either another vaccum leak, or a faulty brake booster. Near as I can tell & best as I can describe, when the brake pedal is depressed you hear the little ******* of vaccum leak hissing like nobodies business. Now... it's not always this way, occasionally they'll soften back up & you won't have the stiffness, or the hissing. ...I'm just not sure what to make of it and hoped that somebody else here knows what I'm talking about. Thanks guys
JD
Old Sep 18, 2007 | 11:46 PM
mrknight01's Avatar
mrknight01
Bad brake booster
I had the same problem on my 72 f250 it was the brake booster the seal had gone bad. Nobody sells the seal alone so I had to replace it. My hissing was coming from under the dash where the brake peddle rod goes through the fire wall.
Old Sep 18, 2007 | 11:58 PM
Red91XLT's Avatar
Red91XLT
Thanks, so about how long untill the system completely fails? I really want to be able to take this truck camping this weekend, I figure if I don't drive it 'till friday I should be alright...
Old Sep 19, 2007 | 12:09 AM
mrknight01's Avatar
mrknight01
It won’t get any better with out fixing it. And I wouldn’t want my family on the road with it that way. IT’S NOT SAFE!!!
Old Sep 19, 2007 | 12:39 AM
rkymtnman30's Avatar
rkymtnman30
The vacuum booster is very easy to replace also check the main vacuum that goes to the booster a lot of times the booster fails due to a bad vacuum from carbon building up in the intake manifold. I defiantly would NOT drive it with the booster out!!!
