1950 flathead v8 question
Old Sep 18, 2007 | 12:24 AM
codys50ford's Avatar
codys50ford
Ive been running my newly rebuil 239 flattie, and all is good. Except for a small flatspot or lag in the beginning of first gear. Its not finished so i havent been able to drive through all gears and see but it seems to just be when i punch the gas is wants to stall out. Other than that it runs great, im wondering if its a carburator issue or timing or something else. If anyone can help please write. Thanks guys
Old Sep 18, 2007 | 05:46 AM
old fool's Avatar
old fool
My best guess would be an accelerator pump in the carb not working.
Old Sep 18, 2007 | 06:36 AM
joedellcarter's Avatar
joedellcarter
Are you running the stock Holley?
Old Sep 18, 2007 | 06:47 AM
TheWiz427's Avatar
TheWiz427
Accelerator pump would be the first thing i would look at. With the engine off look down the carb and slowly open the throttle, You should have a steady squirt of fuel.
Old Sep 18, 2007 | 10:19 AM
codys50ford
joe i am running the stock holley, and i will check the accelerator pump. Thanks for the great info ill get back to let you guys know if thats it.
