Torque Spec?
Old Sep 17, 2007 | 10:26 PM
2003 6.0's Avatar
2003 6.0
Torque Spec?
I changing the front and rear axle lube and need to know the cover bolt torque specs. Thanks!
Old Sep 17, 2007 | 11:13 PM
75F350's Avatar
75F350
Gasket, or no gasket?
Have found that the torque spec of 30 ft lbs is a little tight if you do not run a gasket.
Anyway, all Dana stamped steel diff covers are 30 ft lbs.
Fill plug is 25 ft lbs.
Kinda seems like a bunch huh?
