Ford 9 Ratio Question
Old Sep 17, 2007 | 09:49 PM
Weezman's Avatar
Weezman
Question Ford 9 Ratio Question
I have a Ford 9, can anyone tell me what the gear ratio is, and what kind of vehicle it might have come from. This is what the tag says: WDM DA 1K05
3 . 00 9 S316B
Old Sep 17, 2007 | 10:05 PM
85e150's Avatar
85e150
Looks like 3.00 : 1 ratio if the tag matches the gear set. Numberdummy can decode the rest...might take a while for him to see your post.
Do you have this as a loose part, or installed in a housing, or installed in a vehicle?
Old Sep 17, 2007 | 10:11 PM
Weezman's Avatar
Weezman
The axle is not installed on anything. I took the tag off.
Old Sep 17, 2007 | 10:20 PM
85e150's Avatar
85e150
Well, count the teeth and look in where the spiders are to confirm 3.00 and non-locker. (if you can see the spider gears and not a round drum in there, you have an open diff. The tag would have an "L" in there for limited slip)
As for the other stuff, see previous.
Old Jan 30, 2008 | 03:37 PM
81BroncoBits's Avatar
81BroncoBits
9in ID
I Have nearly the same tag
WDM DA 1E21
3.00 9 S316B
Is on my 81 Bronco 4x4 300in I-6 with OD Manual
definately 3.00 axle ratio with no factory locker and nearly 100% sure its the 31-spline, other than that, someone please tell me
