Thanks much but it doesnt look like the correct wiring diagram. I pulled out the headlight switch and there are at least 8 or so different color wires back there. this wiring diagram only shows a couple. I also was hoping that someone can get me a diagram for the fuse box under the hood. I dont have the manual. I just need to know what they do so i can label them. specifically for the headlight. what fuse is for that?
Thanks,
James
If you are asking about your 1993 F150 it is the right diagram for your headlights.
You did not ask about the marker, dash illumination or power distribution.
Fuse "R" is for the headlights.
