Sponsored by: Auxito
Door wiring - need help!
Old Sep 17, 2007 | 12:31 AM
montanafordman's Avatar
montanafordman
Question Door wiring - need help!
I'm wiring up my doors for power everything and have obtained a new harness - tonight I cleaned all the dust off the harness and connectors etc and labeled with masking tape but cannot figure out one connector in the door - I have all the associated wiring diagrams but still cannot figure out a connector with 2 wires, one appears to be brown and light blue - the other wire just black. Its attached to the same wire bundle as the courtesy lamp as well. Any ideas?
So far I have labled all else:
Power mirror, window, door lock switches
Speaker wire
Power window motor
Power mirror wires
anti theft switch (to door lock)
Door ajar switch
Power lock, unlock actuator
What else???
Old Sep 17, 2007 | 03:20 PM
KingRanchMan02's Avatar
KingRanchMan02
If it is a round two circuit connector with a black wire and a black/light blue wire, then it is the door entry lamp connector. Good luck!
Old Sep 17, 2007 | 03:23 PM
montanafordman
Ok thanks! What is the lamp socket for attached to the harness then? is that for the switch illumination? I thought maybe that had its own internal socket that was wired through the switch harness plugs.
Old Sep 17, 2007 | 04:03 PM
KingRanchMan02
I am not sure. My information came from my 2002 Wiring Diagrams manual. The door entry light is on the back corner of the door panel on my truck.
