odd spark
Old Sep 16, 2007 | 11:54 PM
mooncricket's Avatar
mooncricket
odd spark
i went to set the timing on my 351m today and ran into a wierd prob my motors not getting spark to all cylinders all the time they all seem to get spark at some point but bot constantly ive replaced the coil ignition control module the alternator and th dizzy im just lost now and really need to get the car goin
Old Sep 18, 2007 | 10:59 AM
trinogt's Avatar
trinogt
What was changed since it last ran?
Does it run at all?
Old Sep 18, 2007 | 11:32 AM
Matts72's Avatar
Matts72
Check all your wires. I had this problem from a battery that slid into the alternator and sprayed acid all over under the hood. I had no problems for about six months, now I'm replacing all the wires because they are slowly corroding and grounding out.
Make sure that all the insulation is solid and not cracking or weak. These trucks have a pretty simple harness, you should be able to find one at a junkyard that is in good shape or they are relatively easy to build.
CoyoteKiller
15
Nov 17, 2020 10:50 AM
tjs_79ford
Sep 20, 2009 11:30 AM
Rothschild
15
Aug 11, 2009 04:58 PM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
Hellbore
35
Jun 11, 2006 01:40 AM
