Someone told me that the 1967-1972 F-250 rear ends are a perfect match/bolt-on for 53-56 F-250s.. I'm actually looking for one to get rid of my 4.88 gear ratio and hopefully find one with 3.79.
Good luck!
Pretty much any Dana 60 ring and pinion will fit. You just need an empty 3.54-4.10 case to reuse your 16 spline spider gears. The only thing that is different is the axles from a later rear end.
