I occationally carry several thousand dollars worth of electronic gear (musical keyboards, mixers, amps etc.). If it were just Bud or in my case Newcastle Ale it wouldn't be a concern.
The mechanic who was to perform did the OBD 1 code read could not get my EEC IV to interface with his scanner. This is the only test I asked him to do. Instead of calling me and telling me the situation, he replaces the MAP sensor and disconnects the vacuum line to the FPR. I get told for $245.00 that the truck runs better but they need more time to get it 100%. I said thanks but no thanks.
I picked up the truck off hours on Saturday and looked at the engine compartment prior to leaving to see that everything was OK. I find the new MAP sensor flopped over the wires - not mounted to the firewall. My old MAP was still on the bracket. Also he had capped the plenum outlet to the FPR and left the vacuum line unplugged.
I removed the new MAP, reconnected to the old one, pulled the cap and reconnected the vacuum line to the FPR. The bill said $75.00 for 1 hour labor and $155.00 for the new MAP sensor! You can get one at Advance Auto for $55.00 and a mechanically minded 13 year old could replace that sensor with ease.
On Monday I'm giving the garage back the new MAP and rubber cap plus a check for $75.00 plus tax. Non of this shoddy work was needed. All I asked for was the OBD 1 scanner test results.
Wow, really ups my confidence in some mechanics.
I'm going to do a leak down test as suggested by some on this forum. Hopefully that will pinpoint the 15 to 16 inch vacuum readings I get. Otherwise the only thing I can think of is a bad computer and even that would not explain the low vacuum reading at idle.
