Sponsored by: Real Truck
tilt front end
Old Sep 16, 2007 | 05:50 PM
24Vford's Avatar
24Vford
tilt front end
does anyone know of a company that makes a tilt front end for 2002 4x4 f350 with largeer wheel opening or the options to have it built the way i want
Old Sep 16, 2007 | 07:43 PM
redford's Avatar
redford
FTE Leadership Emeritus
The only tilt front ends I have seen in a Super Duty have been custom made.
Old Sep 16, 2007 | 07:54 PM
24Vford's Avatar
24Vford
thats what i was afraid of i have not had any luck on the web
Old Sep 17, 2007 | 12:25 AM
RACERX7775's Avatar
RACERX7775
what about fabricating an f650 front end on it... thats the only tilt front end that i know of.
Old Sep 17, 2007 | 07:28 PM
24Vford's Avatar
24Vford
i want it to look just like a normal truck with big fenderwells and a cowl hood
Old Sep 17, 2007 | 11:19 PM
RACERX7775's Avatar
RACERX7775
you could always get a good shop to fab something up using your parts.
Old Sep 18, 2007 | 06:09 AM
redford's Avatar
redford
It isn't a real hard fabrication. The only difficult part is fabricating the hinge. Inner fenders, outer quarters and hood get bolted together (sometimes welded). Rear section of the quarter panels has to stay with the truck so it doesn't rub against the door/firewall when going up. Take a look at an F-650 hood, you'll get the idea on what needs to stay and what goes up.
Only other thing is extending the wiring for the lights and a ground strap or two, plus it's good to put in disconnects at this point in case you ever want to remove the hood/fender unit.
