Sponsored by: Auxito
Finding TDC on OHC engine????
Old Sep 16, 2007 | 08:58 AM
Steve C.'s Avatar
Steve C.
I am replacing the timing chains on my '01, F-150, 4.6L engine. The repair manual I am using suggests that I find TDC prior to the removal of the chains. I have a few questions regarding this:
1 - Is there a compression gauge out there with a long neck so that I can check for the compression stroke? If so, where can I buy one?
2 - If not, what are some other reliable methods for checking compression stroke on a 4.6L Ford engine with overhead cams?
3 - If I am replacing timing chains and gear sprockets (cam & crankshaft) can't I just replace them in the position that I find them as long as I secure the cam and crank from turning?
Thanks
Old Sep 16, 2007 | 01:05 PM
Steve C.'s Avatar
Steve C.
I answered my own question - I found a compression gauge w/ flexible extension at the auto parts store.
Old Sep 16, 2007 | 04:52 PM
LastSplash's Avatar
LastSplash
There should be a mark on the crank shaft pully that lines up with a mark on the engine at #1 TDC.
F500Mike
Mar 28, 2013 09:00 AM
paintrx
Sep 19, 2012 10:59 PM
Steve C.
1997 - 2003 F150
Sep 27, 2007 10:44 PM
Gil Chesterton
Mar 16, 2006 02:14 PM
