1978 - 1996 Big Bronco
vacuum t pressure
Old Sep 15, 2007 | 09:25 PM
bigred66's Avatar
bigred66
vacuum t pressure
I hooked up a vacuum guage to one of the unused ports on the "t" on the manifold. I have read that I should get a reading of 18, is this true? I am showing about 10 and am wondering if that means i have a vacuum leak somewhere. My engine idles rough and I dont hardly have any power.
Old Sep 16, 2007 | 06:52 PM
blue beast's Avatar
blue beast
Clean your Idle air bypass if you got fuel injection!! List your truck in your signature so we know what you have!!
Old Sep 16, 2007 | 10:15 PM
bigred66's Avatar
bigred66
Is that the same thing as the IAC? If so do I just spray some gunk or carb cleaner in it once I take it off?
Old Sep 17, 2007 | 08:42 AM
blue beast's Avatar
blue beast
Take it off and spray the heck out of it make sure to hold the solenoid end up so no gunk goes into the shaft!!! Some Rtv and antisieze(because you will do it again!!) And it will be good as new! IAC, IAB Diamond shaped mounting plate with solenoid deal!!
