Offroad & 4x4
tcase question.....help quick..
Old Sep 15, 2007 | 07:48 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
will a 208 from a 95 f150 with a i6 i dont know what tranny bolt up to a E4OD from a 90' bronco instead of the BW?
help!!!
Old Sep 15, 2007 | 09:05 PM
mxzx's Avatar
mxzx
I'm pretty sure all ford transfer cases will bolt to any ford transmission.
Old Sep 15, 2007 | 09:09 PM
flareside_thunder's Avatar
flareside_thunder
might depend on the tailshaft adapter though......
Old Sep 15, 2007 | 09:14 PM
monsterbaby's Avatar
monsterbaby
the BW and np 208 should be fully interchangable as I recall
Old Sep 15, 2007 | 09:27 PM
quadzjr's Avatar
quadzjr
sweet...thanks alot guys...
Old Sep 15, 2007 | 10:19 PM
82F100SWB's Avatar
82F100SWB
That 95 should have a 1356 in it, the 208 died with the 4 speeds.
Old Sep 16, 2007 | 10:28 AM
flareside_thunder
82F100.......unfortunately.......wish they kept the 4 spds...even if the last of em were T18 n T19's.....
Old Sep 16, 2007 | 01:24 PM
quadzjr's Avatar
quadzjr
ok, nother question, will a 205 swap into the 208's spot?
need to know quick...days wasting away...haha
Old Sep 16, 2007 | 01:25 PM
quadzjr's Avatar
quadzjr
im pretty sure its a 208, its a 300i6/m5od?/208 combo...so i was told...
Old Sep 16, 2007 | 06:20 PM
flareside_thunder
I think they quit runnin the 208's in like 87 or so..........I think they started runnin the 1356's after that...hey quadzjr....got any other ford bronco/f-150 lifts for sale for cheap?
Old Sep 16, 2007 | 08:55 PM
quadzjr's Avatar
quadzjr
i think i just read it was 86 so the 208 must of been swaped in, but will the 205 bolt up?
hey flareside, i havn't posted it but ill get rid of my entire d44 ifs frontend and 6" lift for 300 bucks...all the brackets, springs....everything...i just want it gone.....
Old Sep 16, 2007 | 09:56 PM
mustange70's Avatar
mustange70
Yes it will swap, a 1410 yoke will not clear factory crossmember, you need to build a side mount for the mounts on the top of the 205, there are some issues with swapping the 205 and c6 in terms of the tailhousing length (short on and a long one, you can go same with same, but not short to long i think, i dunno i'm not entirely sure), but it should still work, and if it won't you willl find out right away.
Old Sep 16, 2007 | 10:23 PM
quadzjr's Avatar
quadzjr
im going to go ahead and swap the out the 208 for the 205, i wont be running a 1410 yoke on the 205 because it is just going to my second divorced case....
ill just run 1350's...but on the divorced case ill have 1410's
Old Sep 16, 2007 | 10:28 PM
flareside_thunder
sounds mean...I've always wanted to do the tranny doubler swap in something...but everything I get either doesn't run to begin with...as the case is now.....or is too short anyways (like the bronco now)one project at a time..that's why I'm selling it.....
Old Sep 17, 2007 | 08:58 AM
quadzjr's Avatar
quadzjr
yeah, im dealing with the short wheelbase right now....right now as the 300/5spd/208 sits, the tailshaft of the 208 is 6" past the halfway mark of my wheelbase, if i put another tcase after that my rear shaft will be tiny, you may ask why not wait till i put the 460/c6/205 in it to put in my divorced case...but i REALLY want to make it to mudfest in feb...i know i wont get it done, b/c i have to take the cab off and box the frame and make all new crossmembers and chit like that...so i want to get my divorced case in its final resting place right now so i dont have to make new driveshafts when i swap the 460 in....id just have to lengthen the jackshaft a little..no big deal, so im swaping the longer 208 out for the 205 the get that divorced case as far foward as possible....
