please help with truble code P0506!!!
Old Sep 15, 2007 | 06:40 PM
eric_3601's Avatar
eric_3601
Talking please help with truble code P0506!!!
can anybody help me with this to figure out this code.....ok i have a 04 ford-150 and i recently bought a super chips flashpaq and a roush cold air intake...me and my friend program the truck and we install the cold air intake...before all this was install the truck run fine and now the check engine light is on and it gives me touble code P0506....does anybody had this same problem?....if so what can i do to fix it?.....i went to the dealership and they told me that it was my throttle body and some told me that it is my mass air sensor....so can somebody help me please!!!!!!THANKS!!!!....
Old Sep 15, 2007 | 06:48 PM
DaMole's Avatar
DaMole
P0506 - Idle Control System RPM Lower Than Expected
When you installed the intake did you unhook the battery?
Old Sep 15, 2007 | 09:48 PM
KevinAH's Avatar
KevinAH
I had the same problem, I've got similar mods. I replaced the TPS and problem went away.
Old Sep 16, 2007 | 07:39 AM
eric_3601's Avatar
eric_3601
i dont think we unhook the battery....i didnt know that you suppose to...
Old Sep 16, 2007 | 07:41 AM
eric_3601's Avatar
eric_3601
why do yall think this happend?....is that something really bad?
Old Sep 16, 2007 | 09:45 AM
DaMole's Avatar
DaMole
If the truck is running somewhat fine I would unhook the battery for about five minutes. What this does is it resets the computer and it will re learn (will also reset the code). Once you put a different intake on the airflow into the engine will be different, which is why you want to reset it to re learn the new airflow. Give that a try then drive it around regular and see if the light comes back on. If it does then we will check something else. Always start out with the cheapest fix first especially the free ones.
carguy3232
Mar 14, 2014 07:34 PM
Bbasso
Modular V10 (6.8l)
Jun 2, 2012 04:44 PM
waterman74
Jul 3, 2011 02:17 PM
nagetech
Modular V8 (4.6L, 5.4L)
May 28, 2011 02:55 PM
cr2544
2004 - 2008 F150
Nov 20, 2008 04:01 PM
