Wiring Diagram
Old Sep 15, 2007 | 06:08 PM
thehawk75's Avatar
thehawk75
Wiring Diagram
Does anyone know where I can find wiring diagrams for the X?
Specifically, I would like to find a switched (ignition) high amp, wire that goes to the back of the truck. I want to run a vair air compressor off of it.
Old Sep 16, 2007 | 01:00 AM
afreemanmd's Avatar
afreemanmd
I don't think you are going to find a wire of sufficient amperage preexisting on the truck for your air compressor. Unfortunately, you will probably have to run fused lines (maybe directly from the battery even) and a relay. However, I think your easiest ignition circuit is going to be the trailer battery charge circuit. I can't remember exactly which pin it is, but if you look at the flap that covers the female connector on the truck, they are labeled, and you can just tap the appropriate wire. I wouldn't plug the compressor directly into that line (i think its less than 30 amps, I dunno what your compressor needs), but you can use it for the ingnition signal.
Good luck, and hope that helps
Isaac
Old Sep 16, 2007 | 01:28 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Isaac. Your back. You have been of line for a while,
Nick
Old Sep 16, 2007 | 01:34 AM
afreemanmd's Avatar
afreemanmd
haha yeah, thanks for noticing! I'm a senior in high school this year, so I stay pretty busy, especially since its college application time. I'm trying to write all the application essays and all the questionaires for like 10 schools and its driving me nuts haha.
But I try to check the site when i get the chance
Isaac
Old Sep 16, 2007 | 02:23 PM
weekendwarriorfsw32
Master of Strokes
Have fun with that,
Nick
Old Sep 20, 2007 | 12:52 AM
thehawk75's Avatar
thehawk75
afreemanmd:
Thanks for the info, I was afraid I was going to have to do that.
Old Sep 20, 2007 | 09:36 PM
4wdbeast's Avatar
4wdbeast
The trailer battery charge wire is an orange wire fused at 20 Amps. I think it is pin 7 but please measure to be sure.
Bart
GTBksRule
Feb 10, 2013 09:40 AM
frenchy107
Mar 12, 2011 03:06 PM
z1121jack
Jun 25, 2010 11:34 AM
FLJ
Electrical Systems/Wiring
Jun 20, 2009 06:47 AM
qman
Sep 28, 2004 07:39 AM
