Maybe some of you can tell me what special modifications they did to the 390 police intercepter motors. I found one that was out of a 63 police car and the guy just wants to get rid of it but I would like to know a little more about it. thanx, mike
It looked like to me and a friend that the 390PI is an internally ballanced, so another question is would this be a very good motor for a 72 f-250 that pulls a trailer and sometimes hauls a 9 1/2 foot cabover camper? Also what did you mean by an ungrooved crank? On the old 390 that I had built for my truck I had put an edelbrock manifold, cam, lifters, pushrods, roller timing chain,(all from comp cams), bored .030, heads shaved .005, ARP bolts throughout the intire engine, valve job w/new valves, locks, retainers and springs(also all from comp cams) and toped with a carter carb and k&n filter, the ignition system is through a MSD-6 ignition box and coil to match. I would like to use as much as I can on this 390PI. Do you think this would be a good combo to use on the 390PI?
AFAIK On the 61-63 PI & Special they didn't groove the con rod journals on the crank.
On the 63-65 390 Special they grooved them.
Or maybe it was the mains.
[font color=red]Dennis
FTE Assistant Adminstrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
Main journal is grooved.I've got one in the shop.I've wondered if
if this couldn't be done to a standard 390 crank,and if it
would be worth the trouble.
>it.
Check for dual oilpan gaskets, on the Mercury
cop car I had, it had a crank scraper, and
it was sandwiched between two oilpan gaskets...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
