'68 F-100 Ingition Switch Problem?
Old Sep 15, 2007 | 12:02 PM
Wooley Booger's Avatar
Wooley Booger
'68 F-100
240 CID 6 cyl
3 spd manual
Basic truck, no frills
Greetings All - I am having problems with the old Ford and need some troubleshooting ideas. Here's how it the problem(s) presents itself... they may or may not be related:
- over the past year or so, many times if I turn the key in the ignition it just clicks as if a dead battery... but if I tap the solenoid a few times with a screwdriver handle then turn the key, it starts right up. Also sometimes key an arc at the solenoid. Battery is good and charged up.
- I don't drive the truck much (500 mi per year) but took it out a couple of weeks ago. After driving a short distance, it began bucking and lurching. I pulled over and then it would not start up. After about 1/2 hour, I got it started again but same character...so I pulled it home.
- Suspecting something electrical was failing, I replacing the coil first then condenser. The same problem persisted (bucking and lurching) so I put original parts back in. Now the engine cranks but does not start.
- Suspecting a fuel problem, I disconnected the fuel hose from the carb... it seemed to be pumping plenty of fuel... 1/4 of a mayo jar in a few seconds.
So that is where I am now. Could it be a failing ignition switch cutting in and out while driving? Could a failing solenoid cause the problems as I've described? Any suggestions would be appreciated!
WB
Old Sep 16, 2007 | 07:45 AM
subford's Avatar
subford
Sounds like the battery cable is not making a good connection at the starter solenoid. Take the cable off and clean the connections of all of the wires there.
You may have to replace to battery cable.
Old Sep 16, 2007 | 01:03 PM
Franklin2's Avatar
Franklin2
I agree. It sounds like your no start and the bucking and jerking may be related. I don't know about the older trucks, but with the little bit newer ones, they have to have a spot where they tap off the battery + for power for the whole truck. This is usually a smaller wire underneath the larger wire connected to the battery + terminal on the solenoid.
Old Sep 22, 2007 | 12:11 PM
Wooley Booger
OK... we're up and running again.. this is how it played out. The original coil was bad and even though that was the first thing I changed out, it replacement was bad. I put in a second new coil and it fired right up... no more bucking which apparently was the coil failing.
Old Sep 22, 2007 | 03:13 PM
Mil1ion's Avatar
Mil1ion
Most times it is merely a corroded connection.
Maintaining quality corossion control at all battery and igition connection assures efficient operation.
