2003 Superduty trans question
Old Sep 14, 2007 | 10:32 AM
LukeRips's Avatar
LukeRips
What model transmission do I have? It just says "Metric" on the pan.
I have an 03 F-250 (5.4L) and my transmission lines corroded where they connect to the radiator. I'm going to replace them but since I'm under here I'm going to drain/replace the rest of the fluid and do any required maintenance. The truck only has 48,000 miles on it so I'm not sure what maintenance I should do but since I lost soo much fluid I might as well replace all of it.
Also, sorry to be so long winded but my wife said that the truck was slipping on her drive home and would stall if stopped at a light. She didnt know the lines were corroded and fluid was leaking underneath her. Do you think she did any damage to the tranny?
I really appreciate the help guys, this truck has been a nightmare and I couldn't have fixed any of the issues I've had without your help. But, on the upside I've learned ALOT about Ford parts.
Luke
Old Sep 15, 2007 | 03:32 AM
phil6608's Avatar
phil6608
03 F-250 5.4 should have a 4R100 tranny in it.
As long as it wasn't ran for a long period of time wile low on fluid and It did not get to hot.It should be fine when you get it changed and filled back up.
