NEW Pinion Question
Old Sep 14, 2007 | 10:22 AM
dennisb56's Avatar
dennisb56
NEW Pinion Question
Ok so today I took a day off determned to replace my pinion seal. WhoHoo its off, using my impact wrench 1 1/8 socket off it came. Now I thought the yoke would come off instead the whole pinion shaft? is coming off??? Is this correct? I thought the yoke came off and then you removed the seal with a seal puller but instead it looks like if I continued the yoke and shaft would come off right out of the from of the rear. I've stopped for now, am reading the shop manual again and hoping someone gets back to me. I've also sprayed the snot out of the yoke where the nut and washer were hoping it will release.
Any ideas will be appreciated.
Thanks in advance.
Old Sep 14, 2007 | 10:25 AM
dennisb56's Avatar
dennisb56
BTW its the standard 3 speed 3.92 rear, 6cyl F1. nothing fancy.
Thanks again.
Old Sep 14, 2007 | 12:27 PM
dennisb56's Avatar
dennisb56
Well I fingered it out myself, I did realize the yoke had a collar or neck to it that extended back towards the seal, that was what I was seeing. So I got it off, got the old seal off, managed to bend the oil slinger up in the process, so removed it and tried to flatten, straigthen it back out, put in the new seal and reconected the driveshaft. Now I've filled it with 90wt and after it sits for a while I'll go back and check for leaks then a road test.
Could it be fixed....stay tuned.
