my 360 hesitates
Old Aug 9, 2002 | 12:00 AM
kickingford's Avatar
kickingford
Post my 360 hesitates
hi my 360 is in a 1969 f-100. i have changed the timming chain the plugs and wires and distibutor cap but when you stomp on the gas it almost dies then backfires and then revs up is it my carb or timing
Old Aug 9, 2002 | 08:43 AM
lee's Avatar
lee
my 360 hesitates
Hi,
Need more info. Have you been working on the Carb? What type of Carb?
I know that an accel pump problem can give the symptoms that you are discribing. Check to see that you have a good gas stream from the pump when the throttle is operated. With engine off, look down the primary bores and slowly open the throttle. You should see 2 steady streams of fuel. If you have been working on the carb as in a re-build or something, make sure that you have the Accl pump linkage set correctly. The pump should start to discharge as some as the throttle starts to open.
Good luck,
Lee
Old Aug 13, 2002 | 12:38 PM
kickingford
my 360 hesitates
hi lee thanks but what information do you need the carb is a stock two barrel for a 1969 360 and i have rebuild the carb
Old Aug 13, 2002 | 01:05 PM
Ratsmoker's Avatar
Ratsmoker
my 360 hesitates
You are already in the right direction. Either retarded timing or bad accelerator pump can cause this.
Old Aug 13, 2002 | 05:40 PM
Ratsmoker's Avatar
Ratsmoker
my 360 hesitates
