Where are all the Easterners?
#181
#182
#183
-Discovered the problem today when manualy cranking the engine, blown head gasket
Only problem I have now is that the cam sprocket doesn't have enough room to slide forward, without having to remove the timing chain cover
One last idea I have to remove it is to remove the head bolts left the cylinder head up off its dowels then slide it back enough to remove the sprocket 1/8 inch, if this doesn't work I got to take out the radiator and take apart the surpinetide assembly, and finally remove the timming chain cover
Sherm what kind of rims you get? any pics?
If you don't mind me asking there zbig, what do you do?
#185
#186
hey there Z... things are good here, baby is awesome, growing like a weed. '83 is comming along nicely. got my new rims and rubber on there thursday.
here's a video for your enjoyment... YouTube - '83 ford f150
what part of construction do you do Z??
#187
Bonjour guys
first off sherm dammmm that f150 sounds bad *** and looks even better with those tires on i might add, you find out if they rub yet?
Zbig, yea there was gunk... I found alot of build up on each bund you could say, the runners them selfs were actually pretty clean hit them with a preasure washer. best way I've found to remove is throttle body cleaner, just peals the stuff right off. Best part was when I looked inside the plenium, WOW a puddle of oil I suspect it's from the pcv valve.
As of right now in my project I'am working on removing the timiming chain cover. One header is off the one on the passenger side I missing some more bolt before it comes off, that damm fan assmebly is off as well (all I can say is it's a piece of junk)
#191
oil preasure has been fine when I was driving her, I have no idea if there was water in the oil, I've had her for little over 5 months now.
whether the gasket was blown in or out I don't haven't gotten the cylinder head off, though when I turn the motor manualy with a wrench I can hear and feel air escaping were cylinder number 9 is.
#192
#193
Sounds owesome Sherm.Hope you burned that price tag on RR tire.LOL
Made a misteake with taking my kid inside the truck one day,now no day goes by
without,him screaming about get'n in there again and holding the steering wheel.LOL
got new toy 7"GPS.
I can't get lost now I guess.
I'm in renovations Sherm,so I touch everything.
So it was the gasket Skoda.Thinking about cleaning that junk in my int.manifolds.
getting 15L/100km highway and 23l/100km city now,I wonder if it'll help some.
Some say See Foam will do the trick,any ideas?
got new toy 7"GPS.
#195
