No air... Please help
Old Sep 13, 2007 | 10:46 PM
Bird Dog's Avatar
Bird Dog
I have search this site and can't find an answer.
Vacuum pump stops working about every 2 weeks. This causes the air to default to the defroster. I have checked fuses and connections for corrosion. Nothing. Any ideas?
Old Sep 13, 2007 | 10:55 PM
John311t's Avatar
John311t
Could be the seals in the hub itself. Someone will chime in on how to test that, LOL, for vacuum system on my truck goes like this, pump line to tank, tank to HVAC. There are no lines running anywhere else. No possible leaks for me.
bdrummonds's Avatar
bdrummonds
Bad Vac pump possibly. or a leak in the vac lines that only becomes appearant under certain conditions.
Old Sep 13, 2007 | 11:04 PM
Bird Dog's Avatar
Bird Dog
Same here. I know it's not a leak. When it is working I have pulled the wire harness off and tested the connections, there is power. When it defaults to the defrost I pull the wire harness and test, no power... all fuses are fine, then several days later it starts working again. Is there a short somewhere? That's what I'm thinking. But where?
Old Sep 14, 2007 | 08:46 AM
nlemerise's Avatar
nlemerise
Maybe the next time the pump stops running, do a continuity check on the wire powering the vacuum pump.
Canadianpowerstroke
Dec 8, 2013 05:25 PM
raptor2005
Sep 9, 2013 10:43 AM
learpilot
Garage & Workshop
15
Feb 15, 2005 07:05 PM
blackbast
Dec 15, 2004 07:39 PM
