Oil level below dipstick indicator- help!
Old Sep 16, 2007 | 05:05 PM
capehoorn's Avatar
capehoorn
How can I tell if oil is in the coolant or the turbo seal has failed, will it be obvious? I'm going to have the dealer service department check it out when time permits, unless this will damage the engine then I'll make the time ASAP.
Old Sep 16, 2007 | 06:55 PM
blackhat620's Avatar
blackhat620
If oil is in the coolant it is obvious by looking, if the turbo seal is leaking, the oil should be seen out the tail pipe as blue-grey smoke.
If you are really losing a quart of oil in 5K miles i would get it fixed sooner rather than later, as the problem will only get worse.
Coors Man
6.7L Power Stroke Diesel
29
Oct 26, 2018 12:21 PM
maytag906
2009 - 2014 F150
40
Nov 3, 2016 10:01 AM
LeoJr
18
Aug 14, 2016 01:01 PM
johnzenobia
2009 - 2014 F150
Aug 28, 2015 07:30 AM
Thumper23
Dec 20, 2005 06:03 AM
