General turbo question
Old Sep 12, 2007 | 09:43 PM
6.0superduty's Avatar
6.0superduty
Question General turbo question
I would post this in the turbo forum, but you never get replys over there. Anyways, I am building a turbo system for my fox mustang. I was wondering if I should put the mass air meter on the inake side of the turbo, or the pressure side? Also, instead of removing my oil pan and welding in a bung for the oil drain line, can I just make a custom threaded adapter and run my line into the front drain plug on my pan? My plug is on the front of the pan about a half inch up from the bottom. I was just wondering if the oil would still drain out of the turbo if the end was below the oil level in the pan. Thanks for all the help.
Kyle
Old Oct 1, 2007 | 09:33 PM
beezf350's Avatar
beezf350
hey man i had just got done putting in a twin turbo 57mm on mine and if you put the drain under the oil line it might build up oil in the drain tube when your sitting at a light the best is 1" above the oil line man I tap in to my pan and it work fine good luck
