nitrous
Old Sep 4, 2002 | 09:09 PM
nitrous125's Avatar
nitrous125
nitrous
Hello folks, i was wondering would a 125shot of NOS hold up on my 390 its a reman and has 13,400miles on it right now. and i was wondering if the NOS plate would work with my stock 4 hole manifold thanks guys.
Old Sep 5, 2002 | 02:16 AM
Scotty1's Avatar
Scotty1
nitrous
Not in the long run. It is really hard to say weather or not it would hold up and for how long there a ton of factors to look at. But It might once or twice but if it is a stock style reman then not for long. IMHO
Scotty
Old Sep 5, 2002 | 05:27 AM
Ratsmoker's Avatar
Ratsmoker
nitrous
If it is a reman I would say its not a good idea. The rod bolts are probably stock and maybe retorqued at that. If you had a set of ARP bolts and some forged pistons on a mild 390 I would say go for it.
Old Sep 6, 2002 | 11:35 PM
FORD COWBOY's Avatar
FORD COWBOY
nitrous
damn straight it will hold up i have done it myself. i bought a 390 off a guy he told me it had forged pistons in it. which i didnt bother to check. never the less i bolted on a full 7al msd ignition system some,headers,aluminum intake,comp cam,750 holley,and a bunch of other goodies i also put on a edelbrock performer 150hp nos kit because of course i thought i had forged pistons turns out i didnt have forged pistons. but i ran the truck for 4 months before it blew up. i didnt have enough fuel pressure for the amount of nos and i blew up some oiler rings. so theirs another good tip for you if you go for it get 2 fuel pumps
and ps:nitrous rocks
go for it
Old Sep 7, 2002 | 05:20 PM
Ratsmoker's Avatar
Ratsmoker
nitrous
I would like for my engine to last longer than 4 months man. Instead of two fuel pumps why not get a High volume pump and run bigger lines from the tank all the way to the carb. You can only put so much pressure to a carb before the floats stick open.
Old Sep 7, 2002 | 06:42 PM
FORD COWBOY
nitrous
when i say 4 months i mean 4 months of beating the hell out of it. not just going to the grocery store and home in 14.whatever seconds. so you might get up to a year out of it. and dont think for one minute that if you do run nos you wont be wrenching a lot. nos is hard on your motor.and if it is only a reman you will be fixing and replacing things a lot. and the reason for the extra fuel pump is because you need 6lbs at all times when nos is active anything less and you will have problems. it is more of a safety then anything
Old Sep 7, 2002 | 06:52 PM
FORD COWBOY
nitrous
big daddy chuck
General Diesel Discussion
Mar 23, 2006 09:09 AM
edub32
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
Apr 9, 2005 05:33 AM
Drac
Feb 15, 2005 06:45 PM
ivanribic
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Apr 8, 2004 06:08 PM
BVFD1983
General Automotive Discussion
Jan 19, 2004 07:53 PM
