Sponsored by: Real Truck
Tow wiring harness
Old Sep 11, 2007 | 11:51 PM
pf350's Avatar
pf350
Tow wiring harness
Anyone have a pict of their wiring harness for a trailer brake. Go to use my trailer brake and it is not sending a signal to the trailer. When I installed it the red wire had pulled out so I put it back in what i think was the right spot but I don't know for sure if someone could post a pict of theirs then I would know for sure. 01-03 only because I think they change after that. Thanks ahead of time.
Old Sep 12, 2007 | 12:00 AM
Beerstalker's Avatar
Beerstalker
Which harness do you need a picture of, the truck end, or the controller end?
Old Sep 12, 2007 | 09:53 AM
pf350's Avatar
pf350
truck end if you have it, Ther are only five wires to six slots in the plug and the red was pulled out. Before I start crossing wires again i wanted to make sure I at least had the plug set up correctly.
Old Sep 12, 2007 | 10:38 AM
Beerstalker
I can't help you with that end. The plug on the 07 is different.
Edit/ Just got to looking around and found this.
http://www.tekonsha.com/files/BC_Wire_Harness_Chart.pdf
I beleive that yours is the Ford wiring, not the New Ford. So your red wire in the OEM harness should go to the black wire in the brake controller harness.
Old Sep 12, 2007 | 11:49 AM
badlar's Avatar
badlar
Maybe this will help
This is 2001 F250
https://www.ford-trucks.com/user_gal...photoid=147034
https://www.ford-trucks.com/user_gal...photoid=147033
Old Sep 13, 2007 | 12:49 AM
pf350's Avatar
pf350
dude that is so perfect. Now I just need to check to make sure I put the red wire back in the right slot. Thanks for the help everyone.
DKF350
Nov 14, 2011 06:16 PM
86sixbanger
13
Sep 15, 2009 10:50 PM
RIJID-FORD
1997 - 2003 F150
Aug 25, 2009 06:36 PM
CougarXR02
All Things Towing
Aug 13, 2009 09:16 AM
browntown3
Aug 23, 2008 05:23 PM
