Still need some help...
Old Sep 11, 2007 | 11:39 AM
NaviShock's Avatar
NaviShock
I posted a few days ago about my engine revving and the rear slipping which seems to do it together. I'm convinced the rear clutches are going which is causing my rear noise. Not good there. I'm also convinced the two are separate issues. What I would like some help on is the intermittent revving issue. It will rev high whether it's in gear or park. When it's doing in drive the transmission will rev till about 3000-3500 rpms and hold before it shifts. Once again this problem is intermittent. I would think to rule out the transmission because it revs in park. My thoughts are maybe a vacuum issue. My pcv valve seems fine because I pulled it and could feel vacuum. What about the IAC valve? Any help would be greatly appreciated. Thanks
Old Sep 12, 2007 | 07:16 AM
Volman's Avatar
Volman
Navi, what year/engine? 4x4 or 2x4? how many miles? any pertinent vehicle history? been doing the scheduled maintenance?
describe how it behaves step by step from when you start it cold so we'll have a little bit more to work with.
Old Sep 12, 2007 | 12:13 PM
NWBronco's Avatar
NWBronco
Yep yep. More input. Prolly failing Idle Air Sensor. Is the OD light on the transmission stalk flashing?
Old Sep 12, 2007 | 04:34 PM
NaviShock's Avatar
NaviShock
It's a 2000, 5.4 32v intech, 4x4, 86000 miles. I put plugs in back in the spring and it was doing it intermittently before then. I'm pretty on top of the scheduled maintenance stuff. It usually happens cold or warm. Sometimes it happens at cold start up. Sometimes it happens later on while driving. It will just rev to about 2000-2500 rpms in park or neutral. When it's doing this as I previously stated, in drive the tranny will rev to about 3000-3500 and hold there before it will shift. During highway speeds I can see the rpms running almost to 2000 rpms. No OD light flashing. Hope this info helps. Thanks
Old Sep 12, 2007 | 05:19 PM
NWBronco's Avatar
NWBronco
I'm thinking that the ECM may be getting a false signal from the transmission. The engine idle goes up to compensate for the load (Shifting from park to drive). Check the connector on the transmission for looseness and/or dirt. Other than that, the throttle position sensor may be failing. the voltage reading in it dictates what the idle air by-pass valve does.
Good luck with it.
Bob
Old Sep 14, 2007 | 11:21 AM
Volman's Avatar
Volman
Swing by an Autozone and see if it's throwing any codes.
Old Sep 14, 2007 | 11:26 AM
Volman's Avatar
Volman
See if this thread might apply to you
https://www.ford-trucks.com/forums/4...high-idle.html
Old Oct 31, 2007 | 09:28 AM
NaviShock's Avatar
NaviShock
I wanted to post some new info here about the intermittent problem I am STILL having. As posted above earlier, I have an over-revving idle issue and at the same time I have a grinding issue while turning when this is happening which I thought was the clutches in the rear. Once again these two issues always happen simultaneously. Well, the last time it happened I was on a wet road turning from a stop sign. As was turning I bumped the gas slightly and noticed the front wheel spin a little along with the grind acting as if it were in 4 wheel drive. Now I know this truck is AWD but didn't figure that to happen considering it wouldn't normally do that, at least I don't think. Then upon acceleration the truck shifts like it is a lower gear, maybe 4 low or something. This problem will continue or go away. I've done tons of searching and other than the million posts on idle issues, I haven't found any to explain mine. So, I am still confused and frustrated. My best guess right now is the computer acting strange. I have no clue. Any other ideas?
Old Oct 31, 2007 | 09:40 AM
NWBronco's Avatar
NWBronco
Smile
Shift into 4WD and see if the truck exhibits the same traits. The ABS sensor reports wheel speed to the 'puter.
Don't give up dude. When all else fails....get a bigger hammer
