Offroad & 4x4
Disc Brake conversion
Old Sep 10, 2007 | 11:12 PM
scottfreeman's Avatar
scottfreeman
Do the closed knuckle Dana 44s have the same spindle bolt pattern as the open knuckle Dana 44s?
Old Sep 11, 2007 | 05:58 AM
kjett's Avatar
kjett
If you are talking about the 1/2 ton 5 lug axle then I'm not 100% positive, but I believe they are the same spindle pattern as the early Broncos with drum brakes. The pattern is a 6 bolt, wide flange pattern, which is the same as mid 70's -mid 80's Chevy Blazer. Complete offroad sells all of the parts you need in a kit if you are looking to do the swap. If you need the parts break down, let me know and I can post up what all you need as I did this swap not too long ago.
Old Sep 11, 2007 | 09:59 AM
scottfreeman
F250
Sorry, I should have clarified that it is a F250 w the closed Knuckle Dana 44. I know that all of the stuff swaps between the open knuckle Dana 44s, I just wasn't sure if the closed Knuckles were of the same configuration or were an animal all their own
300FOREVER
1966 - 1977 Early Broncos
Aug 24, 2016 04:43 PM
paul97032
29
Feb 10, 2015 04:57 PM
NateTheGreat
18
Oct 23, 2013 03:57 PM
nmidthune
Jul 11, 2013 01:15 PM
ford_nut
Jan 28, 2002 09:03 PM
