Sponsored by: Real Truck
4X4 front axle question
Old Sep 10, 2007 | 04:34 PM
bowhunter1331's Avatar
bowhunter1331
help me out team...
OK front drivers side axle,, just past the yoke, right before it goes into the axle housing...looks like a seal lip is just sitting there...
the seal seems to still be in the right place , but the ring ( hard part of the seal, outer circle) seems to have come off./??
NO leaks, but I am concerned.....
Anyone ever pull and axle out of one of these beast???
LOOKS like a big deal to me.
2005 PSD 4x4 CC
Old Sep 10, 2007 | 05:02 PM
04Xcursion's Avatar
04Xcursion
It's an involved job but not insane, check out the link in the tech folder on how to service the needle bearing in the front end, that takes you 90% of the way to pulling an axle.
If you're not mechanically inclined it may be a little much though
Old Sep 10, 2007 | 07:08 PM
Maxium4x4's Avatar
Maxium4x4
Moved to SuperDuty.....you should find a better answer here
Old Sep 10, 2007 | 08:58 PM
rudedogii's Avatar
rudedogii
My truck has the same problem. I dont think its a problem.
No oil leaks!
Untill I broke the axel. The axel broke at the differential. Then the oil came out. I dont think there is any oil in the tubes.
