The "301" I6
Old Sep 10, 2007 | 10:24 AM
78midnightmudder's Avatar
78midnightmudder
The "301" I6
Ok today is the first time Ive heard of this INCREDIBLE " 301 "
Anyone who knows anything about this...Please enliten me with your Knowledge....
I got a 78 with a 300 built almost to the gills natural
what about this 301??!??!??
Old Sep 10, 2007 | 02:06 PM
rivet96's Avatar
rivet96
the "301" was used in fords f600 and other 5 ton trucks. its basically the same as a 300 only its even tougher! they also made 331. these engines were just built tougher due to the extra weight, etc that they would have to pull. Finding one? very hard. im keeping my eyes open myself! hope this helps
Old Sep 10, 2007 | 02:12 PM
78midnightmudder
Are These The Same Basic Blocks?
Old Sep 10, 2007 | 02:43 PM
Silver Streak's Avatar
Silver Streak
Although I've never heard of the 301, the expanation above does make sense given Ford's habit of building heavy duty engines and designating them 1ci larger or smaller than their regular duty sibling of the same displacement.
Old Sep 10, 2007 | 02:44 PM
TallPaul's Avatar
TallPaul
They made a HD version of the 300 which had a forged steel crankshaft. Mainly big trucks but I think was avail in light trucks for a few years.
Old Sep 10, 2007 | 02:48 PM
78midnightmudder
ok so does this "331" ????whats up with it then? 1 how can you displace 31 cu more in same block? 2 how much more TORQUE are we talking?! i wanna get somewhere close to the most naturally asperated torque as possible!
Old Sep 10, 2007 | 03:22 PM
TallPaul's Avatar
TallPaul
I wonder if you can bore the 300 block that much or maybe it is a stroker? Either way, sounds like fun.
I think International once made a 400 cid inline six gasser!!!!!!!
Old Sep 10, 2007 | 03:45 PM
rivet96's Avatar
rivet96
no 331 was a V8 motor not an I6. i think they made a 391 too (see the patern?)
but a 300 I6 stroker!! that would be awesome!!!!!!!!!!!!
Old Sep 10, 2007 | 03:47 PM
rivet96's Avatar
rivet96
but it would probably sound like a Tractor from hell XD
Old Sep 10, 2007 | 04:35 PM
Col Flashman's Avatar
Col Flashman
Just visit "My Gallery" to see one.
Old Sep 10, 2007 | 05:17 PM
Silver Streak
IHC made a few over 400 ci. The largest was the 501 and there's one sitting between the framerails of my old 4x4. 430 ft-lbs of torque at 1100 rpm.
Old Sep 10, 2007 | 07:25 PM
TallPaul's Avatar
TallPaul
International Gas Inline Sixes. Dates should be about first year of engine.
1946, 749 cid 254 hp@2600 and 585 ft lb
1946, 1090 cid 295 hp@2000 and 938 ft lb @1350
1947, 586 cid 200 hp@2600 and 475 ft lb@1000
1951, 602 cid 220 hp@2800
1954,
372 cid
406 cid
450 cid 142 hp and 370 ft lb@1000
501 cid
1955
220 cid 208 ft lb
240 cid 223 ft lb
264 cid
early 1969 (Scout), 232 cid and 145 hp
1971 (Scout), 258 cid and 150 hp
From Crestline's International Trucks.
But Chilton's says of the 450 and 501:
450 cid, 202 hp@3000 and 422 ft lb@1600 and 7.1:1 compression
501 cid, 215 hp@3000 and 451 ft lb@1600 and 6.8:1 compression
Old Sep 11, 2007 | 12:01 PM
optikal illushun's Avatar
optikal illushun
all these are "FE/FT" engines...
330-FT/332-FE
361-FT/360-FE
391-FT/390-FE
i dont recall a 331 engine being made...
